GoldmistXL
- Jan 21, 2008
I just changed the oil in my 2007 Denali XL and learned something the hard way.
For anyone doing this themselves, please note that the oil drain plug/bolt faces sideways, not down. Why does this matter?
Because once you unthread the oil plug, the oil shoots out sideways approx 12"-18", instead of straight down. So instead of the first quart of oil going into the collection pan, it went all over me and the floor of my garage.
Don't let this happen to you. Make certain that the oil collection pan is positioned so that when the oil shoots sideways the pan will catch it and not allow it to shoot out all over the place.
What is the best way to clean the residual motor oil off of the concrete?
FYI: I used Royal Purple synthetic oil because I read on another forum that Mobil One is now using a cheaper base element that is not true synthetic and is not as good. Amsoil and Royal Purple respectively are now the two best motor oils available.
