07TahoeLTZ
- Jun 6, 2007
Driving and owning cars for 18 years now, I have never changed the oil in a car...always took it to the closest 'quicky lube'....most of this was because I never had a garage. Now I do and have been told the Tahoe sits up high enough to not need to use a jack and stands. I have 500 miles and want to get rid of the original oil and filter and run another 1000 miles on regular oil and then make the change to synthetic (I have 12 quarts of 10W30 Royal Purple waiting).....anyway, is there an 'instruction guide' to changing the oil...I know you need to drain the oil (where is plug), remove oil filter with strap wrench, put a little oil on new oil filter seal, screw it in, replace drain plug and put in six new quarts, but putting on paper is easier than doing...like where to drain old six quarts, etc.....any guidance appreciated. Thanks!
