front Passenger side window rattle..
zeokter
It started a few days ago. First i would roll it up half way and it stopped. Now it has to be rolled up 80% for the rattle noise to stop. Ive installed speakers on that door so maybe that did something. Posting cuz i wanna get a better idea of what it could be. I dont just want to go in blind and try to fix it? any ideas? Has the window rattled on anybody else that has installed speakers on that door? the power windows work fine but the noise is annoying!
WrenchGuy
I just did this and there was no issue.
Double check the wire harness running in there. Its kinda sloppy anyway.
WrenchGuy
LOL....Its mostly temporary. Just so I can try various drivers before I make my own panel. I will be fiberglassing a nice panel once my driver decision is firm.(when is it?) I'm going to play with some 8" and maybe when I make my own panel get a 10" midbass not sure yet....lol
The woes of audio you know.
kingkon
8'S or 10's for a door????? Little big would ya say. A good quality 5.25 component would of been more than enough set up correctly.. or if you just wanted it custom with fiberglass (2) 5.25 components would have been good.
just my opinion. Good luck
WrenchGuy
I'm trying to get everything to keep up with 2 BTL 18's. I do appreciate your concern and definitely know where you are coming from.
Thanks.
"My new Project" is the thread. I have to update.
WrenchGuy
You may also have a rattle from the track and motor. Just give a slight tug around the motor and stuff. Its a little pliable and you may be able to shift the track a hair bit and it may go away.
