Saw this site on another forum
http://repairpal.com/chevrolet-tahoe-1999 put in your info and it said:About this Repair: Fuel Pump Replacement for your 1998 Chevrolet Tahoe
What to watch out for
A clogged fuel filter or problems with the electrical system powering the fuel pump can result in symptoms similar to a failed fuel pump. Have the shop verify that the pump is the problem.
* The parts for the Fuel Pump Replacement service on your Chevrolet Tahoe tend to have a wide range in prices, even for parts of similar quality. You may benefit from checking around to compare the prices at different shops.
Recommendations
The fuel filter should always be replaced with the fuel pump.
Why this happens
A failing fuel pump will not create enough pressure in the fuel system, potentially resulting in a loss of engine power.
Fuel pumps require replacement if they leak or begin making too much noise, which is a sign of malfunction.
