Dieselfamily
- Jan 4, 2015
Just thought i would share this in case someone else has the same issue.
For anyone who has lower than normal oil pressure or if your oil pressure climbs when the engine warms up (My oil pressure was at 20-30 when cold and 30-40 when warm) you might have the same problem i did. The O-Ring that seals the pickup tube to the oil pump needs replacement. Mine basically fell apart when i tried to remove it from the pickup tube.
Took me about 4 hrs and $55 worth of parts (O-ring-felpro 72401) and (Oil pan gasket- felpro OS30693R).
First drain the oil and remove the filter. Then You have to remove the 4 nuts and 2 bolts holding the front diff up. Next remove 1 10mm bolt hold the wiring harness to the oil pan, 1 10mm bolt holding the tranny lines to the side of the pan, and 1 10mm bolt holding a small plastic bellhousing cover to the oil pan. Then you remove the oil pan bolts and drop the pan. Finally you remove the 2 13mm nuts and 1 10mm bolt holding the oil pump pickup tube on, and the pickup tube should almost fall out. Hardest part is dropping the front diff down far enough to sneak the oil pan out.
After this fix my oil pressure is 60-65psi cold and 40-50psi hot.
