Pulley Play?
97tahoe
Just wondering if there should be any play on the power steering pulley? I am not talking about any wobble or excessive movement. It's just that I can move the pulley in and out on the shaft maybe 1/32". Is this allowable or should there be absolutely no play/movement on the pulley?
I ask because I have had a strange noise ever since replacing the pwr strg pump and don't remember if I could move the pulley before replacing the pump.
Just replaced the pulley on the tensioner but I can still hear something coming somewhere?????
Thought maybe the belt being out of alignment might be causing this noise but am just guessing at this point.
Any ideas??
fyremanpat
I have a little bit of play in p/s too. I also had a little squeel. I replaced h2o pump,idler and tensioer pulleys and bearings...with no luck...turns out I was getting cheap belts. Go to NAPA spend the money and get a belt...Hope that works
97tahoe
belt????
Well I know I need a new belt but was concentrating on pulleys in the serpentine cycle.
Maybe I will give the belt a shot.
