The noise is probably comming from your driver side temp actuator. The actuators will lose their "home" position and over extend past their stops. The ticking is comming from the actuator going past the stop, them moving back, and so forth....
For a quick temporary fix, just move the temp slider for the driver and passenger side up a click or two, and it should stop.
If it doesn't, it may be the mode door, or recirc actuator. If that is the case, you'll need to do the following:
Pull your HVAC fuse, or disconnect your battery, or unplug your A/C control head for a couple of minutes. Then reconnect power and don't touch the controls for atleast 1 minute so the actuators will relearn the stop positions.
NOTE: This doesn't always work.
