eshardball
- Oct 9, 2012
Just replaced a fuel injector after still getting a misfire code on cyl #5. Already did the coil and plug and swapped the wire to see if the misfire moved with the spark plug wire. God I hope its not a valve going bad!Time will tell.
I have a code P0442. Can anyone point to the most likely suspects? I did the fuel pump a couple years ago and all the Evap lines on top of the tank looked good but that doesn't mean that one didn't crack between then & now. Everything topside looked Ok (nothing cracked or not connected)
Thanks in advance
Thanks in advance
