Upgrading LTZ 20" wheels from 17" wheels
mohspeed
Dallas
I just bought a set of factory 20s and was wondering if I need to have the dealer reprogram the ECU. I've been reading around and have heard that going from 17s vs 20s can affect ABS and traction control...and that the recommendation is to get it reprogrammed.
I know I can reprogram the new tire sensors to have the DIC display the new tire pressures by following the directions in the manual. When I had 24s (damn the theives that stole them only after I had them on there for a month) I did not reprogram the ECU but did reprogram the tire sensors.
Thanks!
chevytech03
oklahoma
Yes, i would have the dealer reprogram the pcm, it might cost around $150, gm charges the dealer $50, and the dealer usually charge 1hr labor.
Gambler
Baltimore
The diameters are very close, I really don't think it is necessary. If you are sticking with 275/55-20 tires, I wouldn't bother.
mary900
Adams, TN
I had mine re-programed due to my personal concerns about traction control, etc. However, the speedo difference is only around 1% from factory 17s to 20s.
MDTAHOE1
When I switched my factory 17 on a LS to a 20 I put the 2 wheels side by side and they were exactly the same over all size 275/55/20 so there is no need to have any re programming. It would be a waste of time and money. If you contact the dealer I bet they would tell you you need to but that is not so.
metro273
"Crook County", IL
^^^Exactly!
As long as the 2 different wheels, side by side, are the same height or very close, you'll be fine...:thumbsup:
