Anvilair
I have a 1995 Yukon with the 5.7. 166k. New fuel pump, pcv valve, fuel filter, wires, ignition coil, air filter, belts, cap, rotor, exhaust system, exhaust manifolds and gaskets, Vacuum hoses and plugs. Rebuilt trans btw
At exactly 1700 rpm if I let off the throttle or hold it steady at 1700 rpm I get a bog or hesitation. I also at times feel a strange pulsing in that same rpm range. The truck runs smooth otherwise. I cant seem to figure this one out!!!! Any ideas??? Thanks in advance!
Dave
Dave
