Whatever, but pretty sure I'm right...
Such as, there are 2 different 6.0L motors from a couple of years back, the LQ4 and LQ9, I think. The LQ4 has dished pistons, 9.4:1 Compression Ratio, and 300 HP. The LQ9 has flat-top pistons, 10:1 CR, and 345 HP. Maybe the rods are beefier or something but that's the jist of it. So this is GM's modus operandi.
I don't make this kind of stuff up anymore than GM would just take 2 identical motors and then give them each a different tune. Not without at least a different camshaft, etc. They don't usually just push the envelope like that; rather they try to optimize a set of parts with a set of criteria.
The muscle cars of the '60s just disappeared to weak-as-can-be smog motors in 1974. Why did they lose power? It wasn't the smog equipment, there were smaller carbs, but it was all about lowered compression ratio. Engines went from like 10.5:1 down to like 8:1, albeit gradually from 71-74.
While a timing advancing tune may require higher octane too, it is the case with the Caddy engines that they need higher octane because of the higher compression ratio. More compression= more heat= quicker pre-ignition.
Any more questions?
