Hey everyone. I'm a new owner of an old 1998 Yukon, 4 door 4x4 with rear barn doors. I have a couple of questions.
1) If I press the door lock button on the driver or passenger side, should that lock the barn door, or unlock if I hit the unlock button? I would think so but it doesn't work.
2) My key fob will unlock the cargo door, but won't lock it. From all the wire schematics I've looked at, the wiring to the actuator is the same as the rest of the doors. So how is it the keyless entry module can control one door (cargo) and not unlock the others? Is there a separate relay for the cargo door?
My problem is I can't lock the barn doors without physically moving the operating rod inside the door, and I can't unlock it with the door switches.
I'm stumped. Here's what I've tried so far: replaced the actuator. cleaned the plunger switches. Tested for voltage to the plungers and it get's 12v when I use the fob, but not with the door switch. I'm thinking it's not the wiring, it has to be a relay, or a connection somewhere. Any help?? Please!
Ben
Ben
