02 Tahoe Won't Start - Need some help please
austexparts
Austin Tx
I have a 02 Tahoe that wont start. I thought maybe I ran it out of gas (the low fuel light was on), so I added about 4 gallons and it still won't start. I hear the fuel pump come on. The engine turns over, and when the engine turns over a little black smoke comes out. I check all the fuses and I didn't find any what were blown. Any ideas? I read that it could be the Passlock system? Or the BCM? By the way what is the BCM? Any help would be greatly appreciated....Thanks
Sepiroth
Spam Executioner
Kouts Indiana
BCM= Body Control Module.
You ran your truck outta gas. All was right before, I'm assuming. I would check your fuel filter.
The black smoke is from unburnt fuel. Check to be sure that your truck has spark.
austexparts
Austin Tx
Thanks for the reply. I'm curious, if I'm getting black smoke form unburnt fuel, I would assume that the engine is getting fuel. Could the filter be a problem? I hear my fuel pump coming on when I turn the key, could it still be bad?
u2nv
motors really relly on fuel psi to run even though you here pump may not be enough psi. get a psi gauge and hook it up to shraider valve on pass side under eng cover engines with vin code V,T,U is 55-62 psi and vin Z is48-54 psi that is key on engine off specs. then u can also check for spark. if you need anything else or you get awnser to these steps and need to go further in diag let me know.
Fortune50
How many miles on it? Truck's tune is up to date? Checked for spark yet? Does the tachometer move while it's cranking over? This can point to a problem w/ the crank sensor if it doesn't move.
disem
When my Tahoe is left with little fuel it won't start before I fill at least 1/4 of the tank!!! That's 4-5 gallons.
austexparts
Austin Tx
figured it out
It turned out to be a passlock issue I think. I read somewhere if you put the key in the ignition and leave it in the on position it resets the passlock. So I left the key in the on position for about an hour and it started right up.
Grebbler
Detroit,MI
Another tidbit to file away for future battles with these computerized contrivances.:mpr:
Thanks.
Ed
