Hello all.
03 Z71, 5.3L, 106K miles, all stock.
Hearing a squeaking / bird chirping noise from the front of the truck. Pulled the wheels to check the front brake pads; they are fine. Looked for loose heat shields or brackets; none.
Seems to be from the passenger front area.
Not related to engine speed; not related to vehicle speed; can do it cold ot hot; it is intermittent and happens if driving straight or making a turn to the left. Lasts about 1-4 seconds.
Today I WD40ed the idler pulley (near alternator) where it mounts on its shaft, and I did the serpintine belt tensioner with the WD40 too. Then I saw a tensioner near the A/C and sprayed it too.
Anyone else hear a chirping, high pitch squeaking and what was wrong with it? Thank You.
