Upper (on radiator) tranny cooler line is leaking where it crimps and goes from rubber to hard line. Already have new line. Planning on removing grill to gain access to cooler where line goes in. The fittings have those little wire spring retainers things. Can those be removed with flat blade? Do you just hook the end of the wire and pop em out?
And....does this line pass coolant? I don't understand why it connects to the back side of the radiator. Its leaking tranny fluid only so my assumption is no it doesn't pass coolant but why does it connect to radiator?
