justimagination
I know there are many of you here that can give me the correct answer.When my Headlamps are on LOW BEAM...........OUTSIDE BEAMS ONLY
""""""""""""""""""""""""""""""""""" HIGH BEAM..........INSIDE BEAMS ONLY.
Do I have a a filament burned out on the outside bulbs, I thought I was supposed to have all four lamps on high beam. Also how do I check my DRL's ? The green dash light is on in the run position until I turn on thr headlamps then it goes out. I can't find anything to help from the owners manual. Can someone with same tahoe let me know!!!!
david g.
