barn doors locked.. permanently ?
Gun50
So Cal
well I screwed up ..2000 tahoe limited replaced a broken passenger side barn door handle
decided to replace a barn doon handle today. doors still opened and worked just handle was loose had a broken hold down screw.
in the process the latch clasp snapped down into the locked position. Couldn't get it to release. finally used a small screw driver to release the top catch and got it into the open position.. shut the door
Locked solid.. interior panel was off so I climbed inside tryed every handle and rod.. acturators work
but the actual door latch ( not the handle) doesn't function..
pull the hinges ? I'll will still have two doors locked together.. oh frack
I think there are 2 linkages you have to pull at the same time to release the latches.
nathanhanover
This happened to me.. Just keep pulling and pushing on linkage till it unlocks. It sounds like the lock link/s popped off. That just happened to my driver side door. like a 4 hr pain to get it apart,, I had to find the lock link inside the door, I then cut away some of the inner driver side door to fit my hand in there and slid it back on, then put the rod back and shoved the lock in place.
Doors are always a major pain.!!! Oh did you give the two doors a firm shove from outside to set the locks. some times they hang up half way.
