aznpersuasion
- Sep 25, 2012
so ive put the motor back in and tried cranking it to life to no effect. i thought timing was off but its as close as i can get it by hand i think. so if i let it sit for awhile i can crank it and it will back fire through the intake. i have it hooked up enough just to run. no accessories (none). i have the crank angle plugged in, tps, ignition control module hooked up and the sensor at the back of the distributor. i have triple checked wires and firing order. brand new MSD cap and rotor in case it matters.
