LAP TOP GAMER
- Sep 2, 2006
I am frustrated with the output of the jack as no matter what I hook up to it, I have to max out the volume to get any performance at all, what can I do?
What kind of player are you hooking up to it? Have you tried using a headphone-out jack on your music player instead of a line-out jack? You'll need to turn the volume on the player to like 90% of max. I have a Cowon iAudio X5, and I run the volume at 37 (40 is max) out of the headphone jack, and the output via the aux in on the stereo is fine. The line-out levels are inadequate for this on my player. Perhaps you've got a bad cable or one that's attenuating the signal?
Huh. I dunno then -- maybe the output is simply too weak for the Hoe's stereo, or maybe there's something wrong with your stereo. Have you any way to try it in another 07/08 stereo of the same type? Perhaps it's worth a trip to the dealer's to check out a stereo in another truck...(so you don't have to drive the Eurotrash car and use a crappy cassette adapter ). FWIW, my X5's headphone jack is pretty hot at 40mW.
Yep, and a potential aftermarket solution (if your stereo turns out to be "normal") is using a portable headphone amplifier like those from www.penguinamp.com or www.headphonia.com (both made by the same guy). I've got one of his older Royal amps, and it's still working great... There are lots of other portable headphone amp manufacturers, and it's a "religion" unto itself...so do your homework and you'll find something that works well, sounds very good, and doesn't break the bank!
i wish i could on my yukon, i have to use the crappy fm transmitter, on my denali which has the same nav system as the 07 tahoe i got a basic 6 buck cord, have an adaptor for the iphone, turn the volume up and it sounds just like a cd, you may want to check your cord or if your jack is screwed up.
Yeah I am wondering if I have a Jack issue. I don't want to spend money on it if it is a defective unit that can be covered on my extended warranty.
your over your 36k mile b2b warrenty.
wow, i thought i drove alot.
The Aux Input plug on the Tahoe's panel accepts a standard line level input. What I'd do before doing anything else would be to take a 110V CD player on an extension cord out to your truck, set it on the seat, and feed the output of the player to the Aux Input to verify the input is working properly. I've seen far too many MP3 players with too low of an output, or even more common, files that were improperly recorded.
im thinking about getting this.
http://www.shop.com/Boostaroo_Headphone_Amplifier-46982382-61459172-p!.shtml?sourceid=298
