Its about a 45 minute job.
10 to jack up front cross member and place jackstands under car
20 to do front swaybar
11.5 to do the rear (my time today!)
Front:
Unbolt the sway bar end links (2 ea, 15mm bolts)
Unbolt the bar from the frame (4 ea. 10mm bolts)
Lube the new bushings with supplied grease and reinstall in reverse.
Rear:
Unbolt these endlinks (2 ea, 19mm bolts)
I have only done a short drive in the rain, with my dash apart for the aborted lockpic install, but it definitely has a lot less body roll now.
Front:
Rear:
