L O C on stereo screen
joeysworld
1999 TAHOE
I had my tahoe on car stand for a few days while I was replacing the fuel pump. While it was on stands, it was also disconnected from the battery.
Putting it together yesterday, I read, "L O C" on the screen/menu.
Does anyone have experience with this?
qlc1964
st.louis mo.
some one put a lock number code on the radio if someone steal it call a dealer see
if they can reset it.
96ProCompTahoe
Indiana
they can reset it but the guy at the salvage yard said its not cheap for them to "unlock" it.
qlc1964
st.louis mo.
might be a good time to replace the radio with a better one
or if you take it to the dealer be sure they give the code.
each time you un hook the batt pos it will lock
Razincayne
SE Washington State
Might give these guys a call. They charge $10.00 and will e-mail your unlock code to you. Sure beats the big bucks you will spend at the dealership. I took the below information off there website. Might be worth the phone call.
( 407-830-0777 ) Sure hope this helps you out.
For Coded GM Car Radios with "LOC" or "InOP" in the Display
Buick, Cadillac, Chevrolet, GMC, Oldsmobile and Pontiac
LOC - There is a customer's code stored in the radio. The car radio is locked.
To unlock the car radio - Have a pen and paper ready. Push and hold stereo preset buttons 2 and 3 simultaneously for several seconds. Three digits will appear in the display "XXX", write them down. Push the AM/FM button, three more digits will appear in display "YYY", write them down. Remember this six digit number, "XXXYYY" when you call them.
After your payment and six digit number sequence is received you will be emailed the unlock code for your car radio. Each radio code is retrieved independently, you will be emailed the unlock code for your particular number sequence. Normal response time is within 1-6 hours. Holidays, weekends and late hour orders may be delaye
When your unlock code is received by email, locate the "Hr" and "Min" buttons on your stereo. Most unlock codes are four or six digits.
Unlock procedure for four digit codes. Push the "Hr" button, 000 will appear in display. Press the hour button until you match the first one/two numbers of your unlock code. If first two digits of unlock code are greater than 9, the display will become a four digit number, continue until first two digits match unlock code. For second two digits of unlock code press the "Min" button until numbers match. When unlock code is entered into display, push the AM/FM button. Radio will become active.
Unlock procedure for six digit codes. Push the "Hr" button, 000 will appear in display. Press the hour button until you match the first number of your unlock code. For second two digits of unlock code press the "Min" button until numbers match. When first three digits of unlock code is entered into display, push the AM/FM button. Repeat the above process for second set of three numbers of unlock code.
joeysworld
Sorry it took me so long to repost.
I unlocked it, and for all of you with "L O C" on your stock radio, I believe 2003 and older, here's the procedure I found from a very kind individual that I'm going to share with you.....FREE!
This procedure is FREE! There is no charge..... It worked for me.
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can “unlock” your radio and then “re-lock” it with a new code if you wish. Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140
08. Press 1 then # (pound). You’ll hear “Invalid Code, try again”
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction in your Owner’s manual. Use the code from STEP 11 instead of your personal code.
TahoeGoBoom
just outta curiousity, and very off topic, are those the '07- up LTZ 20's on your tahoe? cuz thats exactly what i wanna do on mine, either that or trailblazer ss rims. but the dealer wants 1800 for em... and im not into theft. so now i gotta find someone who got some 26's n will sell me their old stuff. :(
joeysworld
Yeah, they are off of an 08 chevy. Not sure if it was an LTZ, but the person who was selling them was buying some new rims/tires and lifting his truck. Look on craigslist. Thats where I found mine.
96cherry
livonia
Damn!!! i want those wheels i call those all purpose wheels looks good in the summer and winter, nice truck joey
joeysworld
Thank you! Going to sell my other tires and rims that I replaced these with. Going to place in the for sale (if available) section. Will have pictures as well!
Rick Covalt
Has anyone used the 800 number lately? I tried to call it and it just rings and never picks up.
Thanks
