Can anyone tell me where to find the reverse wire in the dash area? I have to tie it into a nav system (Z2). I also have to connect to the VSS. Based on the research I've done on this forum, the VSS is the green wire in the upper right corner of the wiring junction block near the brake pedal. This is based on the picture that I saw in another thread. Can someone confirm this to me? This picture seems to indicate that it is it but has a strange question on the photo, asking if the wire is in fact the VSS.
I'm trying to do as much leg work as possible before diving into this installation.
Thank you.
Thank you.
