96ProCompTahoe
on the drive home i noticed the oil pressure guage dropped from its normal 50ish to 40, and when you let off the gas just above 20. no coolant in the oil, no loss of oil, trucks not running any different that it was before the pressure dropped. no noise, nothing.
so how likely is it that i have a bad oil pressure sending unit? i ask because when i first picked it up is was still pushing 60 as many have stated their vortecs run at, then it dropped to 50 after an oil change, and stayed there for the last year or so. and if it could be the sending unit where is it?
or am i pretty much screwed and looking at a rebuild? 96 tahoe with just under 170K on the clock. if im looking at a rebuild what can i expect to pay a shop to do it? the tahoe is (or was) the only reliable vehicle i have at the moment and time is a major factor.
