Copper&BlackYukon
- Sep 9, 2008
Here is what I have been doing with my free time since I picked this beast up around thanksgiving. I picked up this 6.0L 4L80e locally on ebay for $1,136. One of the headers was damaged from the accident the truck was in. I was able to find a replacement set of 317 heads on ebay, that have a been completely overhauled, New LS2 Valves, Springs, Seals, and has been surfaced for $375. I was also able to find a Magnacharger, on ebay, MP112 intercooled, very lightly used for only $2,800. I will be installing a cam shaft I also found on ebay that had 1000 miles on it for $190, Lingenfelter LS1-GT2-5 222/222 .566/.566 w 1.7 rocker 112 CL. I went to summitracing.com and ordered pretty much everything I need including, all tensioners, idler pulley, ARP head bolts, damper bolt and other bolts.
The block is going to take a trip to a local engine shop just to bore out the cylinder walls to get rid of some very mild corrosion from moister that leaked in from the crack in the header, and to accomadate the forged Mahle pistons 4.010. Then I will be hitting it with the gloss black engine enamel, and then she goes back together.
Still plenty to do but that is the progress so far...
