Need help with my 2008 4x4 tahoe..
Dirtiest Hoe I Know
2008 tahoe ls
i try to put it in 4x4 but it does not engage...
i can hear the transfer case switch, but then if i hold the brakes and try to spin the tires you can hear the front differential not engaging/ grinding.
yes, i know the grinding is bad.. and not to do it..
any ideas what my problem could be?
has anyone had a problem similar to mine?
TahoeJo
Vancouver Island BC Canada
Hey man,
It sounds like there's something seriously F@CKED with your front diff. Have you drained the front diff to inspect the fluid for metal shavings/chunks? It should still be under warranty, but they might try to deny it since you have a lift kit and bigger tires which will put more strain on the front diff. What kind of lift kit do you have in that thing? It looks sick!
Dirtiest Hoe I Know
The funny thing is.. I lifted it after the differential was already fcked.
The car has over 100k miles so idk about a warranty being issued
Is there even a drain plug on the front differential?
I haven't been in the mood to drop the differential and take it apart after putting 20+ hours into lifting it.
Maybe after Christmas
The truck/Tahoe looks better now with the air ride shocks, levels it out more than in the picture.
TahoeJo
Yes there is a drain plug on the front diff, I think it's a 13mm... You'll have to remove the front skid plate to access it. The skid plate has 4 15mm bolts. GM will sometimes grant you what's called "goodwill warranty", which is whn it's past the normal warranty period. Basically it's to keep you as a satisfied customer. Since you did the lift yourself i doubt you get much work done at the dealership? The dealership I work at grants goodwill all the time... you might have to bitch a couple times, and if the service advisor says no, ask for the service manager. Doesn't hurt to ask especially if it's gonna save you some major coin. Good luck!
