No Sound/Power escalade
evillesi
ok just picked an 04 escalade this last weekend. dealership is going to take care of this problem but being a car junky i am trying to figure it out myself before i get it in the shop.
i have the navigation unit all factory. the nav powers on just fine but no sound will come out of any of the speakers. i have also noticed that the door chimes and back up beeper are not sounding either.
the rear entertainment center is not powering on. the clock doesnt work nor does the 6 disc changer.
i am at a loss for what has happening here. i have checked all of the fuses pulled the nav to see if the harness was hacked up, which it is not.
i am really about to take the vehicle back and say screw it. this seams to be a major issue. i have not been able to find any similar issues anywhere.
any help will be appriciated!
OmarR
Indianapolis, IN
I had this happen to me once. Disconnecting the battery, waiting about 5 mins, and reconnecting it fixed everything.
*Edit*
You also check the fuses under the hood? In the lower right side of the fusebox there are 3 fuses labeled radio, radio amp, and info.
Hardin Thicke
The door, and seatbelt chime tones are generated by the audio amplifier and come out of the door speaker. I'd look there. Have you checked its fuse?
evillesi
The fuses are good. Unless their is a fuse in the amp. I will try the battery. I am taking it back to the dealership saturday. Ill keep you updated thanks for the response
Hardin Thicke
There is no fuse on the PC board. Although it hurts to say this, I'd suspect the amp.
evillesi
I don't really care what it is. They are taking care of fixing it
