Gordo
So has anyone tried to renew their onstar subcription and found out you couldnt do it anymore. It turns out that since the fcc changed everything to digital anything that is analog will no longer work. You gotta go to a dealer an have an "upgrade" installed you guy can check this out at www.onstar.com or press the onstar button in your trucks and will let you know if you need an upgrade or not. The only problem is you gotta get the upgrade asap while supplies last or you cant get it anymore later on.
