Mine is a 2002 and it's pretty easy from what i can see, there's a big hose thats on the drivers side, comes out from nearly the center of the engine makes a turn to the back of the engine then turns down to the drivers side rear rocker cover and it just pulls out on mine, pull the hose up and there's a mechanical plunger like thing with suction if the engine is running.. Anyhow you should be able to pull that metal thing out from the hose it's attached to and put a new one in.. Get the new one first of course, if it takes longer than 5 minutes, re read instructions. 2002 and 2006 are pretty similiar from my understanding so if they changed that, well no harm in looking first.
