Hello All
I am in the middle of replacing a pwr steering pump on a 97 Tahoe. As stated in the manual, I have removed the serpenting belt, pulled off the pulley, removed the two lines (from the gear box) and removed the three bolts holding the pump.
My problem is the pump won't budge!!! I am not sure if there is a step not mentioned in the manual that any of you may know about?? I can get it to pivot slightly by placing a screwdriver between the front of the pump and the AC bracket but nothing close to actually coming out.
Do I just need to give it a bit more elbow grease or what???? Any suggestions are greatly appreciated.
