The VIN doesn't tell, I think its on the service identification tag in you glove box. The RPO code will tell what you have. Take a picture and post it, there are several sites that can decode the RPO codes.
In the past I posted vin numbers and the build sheet told the rear axle code...I posted a vin yesterday and no reply...and doesn't look like anyone else has gotten a reply in a while. where is the rpo code sticker?
It's in the glove compartment I found a junkyard one with like 118k on for $550 having my mechanic put it in today hopefully done soon I want to drive my truck again haha
yeah everything I read it says swap it out. That it can cost alot of money and some seem to have a little noise to them again later. And others have to repeat building them again in 20k. Yet other axles last 250k.
Mine was making a shuttering vibration when I gas it gas and when I would go from drive to reverse it would take a sec to engage and then it would bang I just got it swapped out and got it back today I am happy with the results had to change a few other parts in the rear end but all set and back driving it haha and finally out of my work van for 3 weeks
that sounds like trans. I had to rebuild my rear end and i did all the work cost me about $800 or less. bcause the spider gears blew up. but my truck still takes a sec to change from any gear to reverse it takes a sec. and i know its the trans. i will remove the trans but to get that rebuild it will be about $1200- 1500.
I used to be able to hear it when it when I was driving normally but when I picked it up today that banging sound was gone and I have it a good little test on way home to check to make sure everything was fine haha everything is good hopefully it's last for a while
