Service 4WD light on 99 Tahoe
jbloomfi
Does anyone know how to determine the problem when the service 4WD light comes on? I have the transfercase with auto 4WD. I have recently replaced the front axle actuator and all the lights are off on the switches. Also, when I start the truck all 4 lights do come on for a second or 2. The other question I have is that the truck seems to be in a limp mode, are these 2 issues related?
Thanks for any help!!!
Jon
jbloomfi
Thanks for the pointer, I tried that but it does not work for auto 4WD option. :confused2:
gilgesan
99 tahoe service 4wd light
did some reading and found out how to get flash codes for 4wd. my problem is there is no pin 13. it is empty. the troubleshooting guide said to ground pin 13 in the data link connector but it is empty?
Probably depends upon your year of rig and model of transfer case...... Plus this thread is 5 years old....
Jeff B
sorry to pull up an old thread like this.
I am having this same issue and no connector in the #13 of the data link to read the TCCM code.
