T-case won't shift into 4wd
Discussion in 'Technical Discussions' started by bplayer405, Jul 31, 2019.
  1. bplayer405
    bplayer405 New Member
    Jan 13, 2019
    99 Tahoe 5.7 NP8 t-case refuses to shift into 4wd. Blows its fuse when it tries. With the encoder off I've tried to shift the t-case by hand and it will not shift much past the 2wd location. I can shift into neutral. It will be a while before I can remove the t-case and have a chance to do any repairs. I'm basically looking for info as to what may be binding internally to cause it to not shift in into 4wd?
    Sent from my SM-G973U using Tapatalk
