XCaliberTactical
- May 2, 2008
I am hoping for some feedback from those of you who have performed modifications to lower the ride height of your vehicles. In the spring of '07 I hired a custom shop to install a set of Eibach Pro Kit Lowering Springs on my father's '07 Tahoe LTZ 2WD with Air Suspension/Auto-Ride. Since my father is in his 70's (but not quite ready to give up commuting all his golf buddies), I thought the 2" front and rear drop might help him to comfortably climb in and out of the vehicle. But since the truck doubles as my law enforcement and military product sales business vehicle (I'm not quite ready to give up my sports coupe just yet), I felt it best to keep the 20" tires stock since occasionally I must go off-road to various firing range. We did change the wheels but kept them to the stock factory dimensions. About 12,000 miles later and just recently the dealer during a routine check-up noticed uneven wear on the inside of the tires which alarmed my father to think there is a defect in the Tahoe's design. I am well aware that lowering sometimes will result in this condition but I had assumed that the shop had made adjustments for this but now I am uncertain.
Is anyone else having this problem or have a solution? I know that Eibach now has Pro Spacer and Alignment Kits (Front +/-1 degree camber adjustment or Front +/- 1.5 degree camber/caster adjustment) but I'm uncertain what kit to purchase and use and the shop that I had used isn't certain themselves as they are used to doing off-road 4X4 lift kits rather than lowering kits.
Any help would be greatly appreciated!
Thank you!
Apichart "Sam" Chong
www.xcalibertactical.com
P.S. We're friends with Dillon Aero who's GMC Yukon XL with their M-134D 7.62 NATO minigun mounted on the roof video has circulated around the net. Next time I'm over there I'll see if I can snap off some pics of it and post it here sometime.
Thank you!
