I have a slight suspicion that my 07 is down on power. Before I take it to the dyno I'd like to see someone else's numbers.
Did your tuner take out any of the torque mgmt?
Here is a post that I wrote a while back - this should give you an idea of what to expect (keep in mind the HP loss through the drive train - the posted 320HP from the factory is at the crank shaft... not rear-wheel...
Previous post -
The numbers are:
My initial run - 264 HP @ 5500 rpm (basically redline); 279 ft-lbs torque @ 4500 rpm
After a few runs/tunes - 262 HP @ 4800 rpm; 298 ft-lbs torque @ 3900 rpm
Key points - I picked up 25 ft-lbs of torque at the real-wheel the entire duration from 2500 to 4500 rpm; I also picked up about 20 hp the entire duration from 2500 to 4200 rpm; You really have to see the sheet to appreciate the difference - it is slightly misleading that I lost 2 HP overall - because that was at redline versus what I gained in all the "driveable" rpm range.
It seems like there is more left on the table for you there. Under no circumstances should you lose HP. At the very least, you should maintain the stock HP up top. Just because you gained torque down low, doesn't mean you cant gain torque up top as well. (HP= (torque X RPM)/ 5252)
There is no reason for you to have lost torque at 4800 RPM and above. Something is not right.
Ah yes, I had a brain fart, I was comparing torque gains at 4800 to the stock output at 5500.
What was the tuned HP at 5500? For best acceleration at full throttle, you should shift after peak HP which should be around 5700.
If the tune was still stock above 5200, then there would be more power on the table. You should never see anything fall below the stock tune numbers. My guess is that if power is less then it detonated. This biggest issue I see is while you gained hp at 4800rpm you lost 24hp at 5500rpm. Seems like whatever changes were made they were worse than stock above 5200.
Unfortuneatly we don't have any 07 Tahoe dyno sheets as only a few sheets are actually kept. All of our data is kept in log files.
Can both of you post your dyno sheets (baseline and after mods) and also do you know what gear was used? I am curious what the area under the curve and the air/fuel ratio looks like.
Yeah, you should not lose 20 hp up top. From your description, it seems like power was shifted to the lower rpms (more daily usability) versus up top. As long as the A/F ratios are inline and you are satisfied with the results (more mid-range power), the tune should be ok. If you don't mind, how much was the dyno tune and is there a way to switch back to factory settings during dealership visits?
