I have no idea what to search for, so here goes. This is an ongoing problem and we're at a loss for words and a shop is out of the question.
A friend of mine has a 98 Tahoe with literally 10k miles on a crate engine and it won't start. It sounds like it really really really wants to start.
While cranking, it will have bumping sounds coming from the intake, inconsistent cranking that puts an awful amount of load on the starter.
We've already burnt up a starter as a cause of this problem.
A friend of his has a code scanner which said map sensor or intake gaskets are the problem. So I replaced the map sensor, lower intake gaskets, plenum gasket and a few other small ones and its worse than before.
When I removed the 8 lower intake bolts, the driver rear side were so loose, I could take them out without tools, but thats just 2 out of 8 bolts.
Before this, it would at least run with partial throttle to keep it alive, but once you let go, it will stop like it hydro locks.
We're going to run codes again to see what its saying now.
Any suggestions?
I think its the pressure regulator and genius spider injection system.
I don't know what to do. HELP!!!
I'll see about getting video of it cranking.
Any suggestions?
