03 Tahoe OBD port not working
iamgobono
I have an 03 Tahoe lt, and the OBD port is dead. Is there a fuse for it? How do I start my search? Loose wire? Help... engine light is on.
Thanks,
Bo
tonymac617
Boston, MA
After searching online briefly, some folks with the same issue say there is a fuse for it, but they dont give a fuse location nor does any search results provide the fuse box labeling for your vehicle. Check the fuse box under the hood, inside the vehicle and if all else fails, your owners manual for fuse and location.
JennaBear
CA
Sounds like your cigarette lighter fuse is dead, it is among a triangular cluster, on the drivers side, closest to the windshield.
tiggermike
Your answer helped me tremendously as I was able to pinpoint my problem. It was the cigarette lighter fuse that was causing my OBDII scanner to not communicate with my vehicle; although this fuse is actually located in the fusebox under the hood in my 2004 Tahoe. Thank you for your answer and I really appreciate it!
