I have my new 20" wheels that have a slightly more positive offset (+35mm) when compared to the stock 20" wheels (+31mm). The fronts look perfect and sit just inside the wheel well. The backs look ok but would look better if I could move them out a little. I have found 1/4" aluminum wheel spacers that simply slide over the existing studs and then you put the wheel back on like normal. Installing the 1/4" spacer will move the new wheel out by only 2mm further the stock position so lug length is not an issue and any impact on suspension/bearings/etc./etc. will not be an issue. Any TRUE/actual concerns/issues using these on the rear wheels only of my 2007 Tahoe (2WD):
http://www.midwayautosupply.com/show...iliateid=10050
