Pull the connectors at the relay and resistor, check for voltage on the relay orange wire or the blue, tan or yellow on the resistor connector. Check with the blower on. You should be seeing 12V on the orange relay wire with the blower on high, the same for the resistor connector (except the dark blue) at the other fan speeds.
If no voltage on any of those, then the control panel probably is the issue. If you end up buying a new one, go with the Delco over the Dorman version. I bought a Dorman and it started smoking after a few minutes.
Also check for voltage on the red wire at the relay. It should be hot at all times.
Did you verify that the blower ground wire is good?
Sent from my iPhone using Tapatalk
