Hello I have a odd situation. My wife went out 2 days ago and truck would not start. Battery was dead,she got a jump And I came and picked it up and took it to work. Battery was no good replaced And then checked for a draw. and it had a big one 4.5 amp ignition off draw. I found draw from abs c/u I pulled fuse And it dropped to 0.02 amps. Vehicle does not have any recalls due per dealer. My question is should I replace the abs unit and if I do does it have to be programmed thru the dealer.
Thanks
Thanks
