'92 Yukon won't turn over
DVHammer
somebody local also suggested checking the crank sensor, where is it and can I bypass it. Is it normally open or closed? found that if not detected it will not allow the pump to run, also do you think that would show up as a code if I purchased a code reader from someplace like NAPA?
Jason_Ridgeway
Is you check engine light on?If it is more than likey it will set a code! Check around your harmonic balancer (always a good place to start) for your crank sensor.
Hardwarz
Ohio
I don't belive that the crank sensor is a constant on/off sensor. I believe it's a hal effect sensor and sends pulses back to the computer.
Hardwarz
marinekilz
NYC, Basking Ridge NJ
here is the location
  • ALLDATA Online - 1998 Chevy Truck K Tahoe 4WD V8-5_7L VIN R - Component Locations.zip
