Ya, def. check the fuel pressure, its easy to get to the access point, if you look at your Intake Manifold, where the air comes in, you can look down on the right (if your facing it) and you will see two metal lines running into the IM, follow them back a little and jump over the Hose, you will see a little screw on cap - you can check the fuel pressure there - now the Fuel Pressure Guage is 39.99 at Autozone - you could however, go and buy a new fuel filter, and while installing it (while the Old one is out, and before the New one is in) - have a friend turn the key on, and see how fast the gas is coming out (watch your eyes) - now, if it is just barely coming out, than its the fuel sender unit - if it is Flying out than its ok - remember it needs to be coming out at around 55psi - if it seems like it is only coming out like 10psi (water hose effect comes out, and then just drapes down kinda fast but not really) if it is 55psi than it will shoot like a water gun and gas will go everywhere - just turn the key back off.. if your anything like me i had to hollar at my friend who shut the door with the window up... *erg (gas got in my eye) - i just replaced my fuel sender assy. again... and i bought the fuel pressure guage, but went ahead and checked it by doing the fuel filter method first wound up taking the guage back because it was un-opened
