Well, yesterday I had a little time to wrench, so I thought I'd try to fix my horn... I've needed it a few times lately...
The problem was the horn switch. The part is incredibly simple... just a metal contact that is spring loaded to keep it in contact w/ the steering colum when the steering is rotated. It receives ground (-) power when the airbag/horn pad is pressed.
Anyway, as it turned out, the spring was kinda compressed (I guess after 10 yrs of being in place). After testing the horn w/ a jumper wire, I knew the connection was ok. I just pulled out the horn switch, and pulled on the spring to stretch it. That's it! Now it works perfect!
Thanks Treepete for the reference and info you supplied! That really helped me find out what I might be in for.
