Hi. New here. Lots of questions since I've never before owned a remotely modern GM product until now and this one has a few issues.
Mine is a 1996 Tahoe, 4 door/4WD, which I purchased from a nice little old lady that just used it to go to the store to get food for the stray cats she fed (True). Very nice woman, actually, and smart, but way too much vehicle for her, so now I have it and she has a Honda station wagon.
I've cleaned this thing up and have recently started in on the hardware and of course, getting it registered and smogged. Today it flunked smog. CO was too high, NOx was marginal but passed. HC was OK.
I have an AutoTap scanner and took some readings. Everything looked OK except one of the secondary O2 sensors is reading low, 30-50 mV, when the manual says it should be reading 130 to 870 mV. My understanding is that a low voltage output means lean conditions, which should be what you want in the secondary sensor if the CAT is working. The first sensor cycles between around 125 and 850 mV, as expected. On the other bank both sensors cycle between around 125 and 850 mV. To me that says the CAT on that side is not working. Am I interpreting this correctly?
Other items checked:
So am I interpreting this right? The bank with the low-reading O2 sensor is working, while the bank where the upstream and downstream O2 sensors follow each other.
Either way, it sounds like I need a new CAT.
Thanks,
Mike
- MAF: 0.87 lb/min/ (6.5 g/s), 5-7 g/s is normal
- MAP: 9.2 in Hg (31.1 kPa), 38 kPa is normal
- ECT: 194°F, 200°F is normal
- IAT: 91°F, but I had the hood up. It started to climb when I closed it. Normal is 107°F
Thanks,
Mike
