vinmhslax15
- Nov 20, 2008
So my truck has a vibration problem. Its way bad over 70 the whole front end shakes even. It also thuds when you initially push the gas. I already figured the u joints were going bad but today it got way worse. The check engine light came on and the car keeps coasting almost as if its on cruise control, it barely slows down at all. Also now i can feel shaking in the front end drivers side. What could be wrong now? This started after I went over a bump, are the problems related or is there now 2 seperate problems?
