OK... i just got to fixing my horn, which got me to take apart my st column.. which made me think about my high-beam problem. My high beam went out many yrs ago. If I pull the stalk toward me, I hear the click, but it does absolutely nothing. No high-beam... not dash indicator, etc.
At one point I thought it was my aftermarket alarm system... maybe it was tapped into the light's wiring, but I realized that the alarm doesn't activate the brights at all.
Is it common for the turn signal/hi-beam switch to go bad?
Relay and fuses are fine... but no clicking sound.
-Also, my dash lights don't turn on automatically sometimes... normally it turns on when the parking brake is released... but if I toggle the parking brake switch, it turns on and stays on... like normal operation.
Is the headlight switch (the one you rotate) also a common part that goes bad?
-One more... my right/rear window switch seems to be bad... I think. Basically, I can operate that window w/ the driver's master window controls, but the switch on the actual door does nothing. Is this also common? How did you fix?
Anybody have similar problems?
Thanks!~
Thanks!~
