My ABS light is on if I go over 5 mph
vinceseg
I paid the speakership 160 for diagnostic. They want 3k to fix. 2005 Hoe. They say I need an ABS module and valve.
Anyone have a source. I think rockauto has it but these clowns aren’t even coughing up part numbers.
Vince
PNW NBS Z71
Member
Supporting Member
Eugene, Oregon
Yes, I agree that it sounds like a speed sensor. Lift the front and check for play in the front hub bearings. If enough play, it can damage the speed sensor. Check all wiring leading to the sensors and check all wiring at the rear. This is something that is a common occurrence when the bearings are too loose.
Just in case: https://www.rockauto.com/en/moreinfo.php?pk=9314280&cc=1431156&pt=1844&jsn=938
If one of your RPO codes is JL4, then this module will not work. That means you have Active Traction Control. Then you need this instead: https://www.rockauto.com/en/moreinfo.php?pk=10114920&cc=1431156&pt=1844&jsn=940
Valve without JL4: https://www.rockauto.com/en/moreinfo.php?pk=1416050&cc=1431156&pt=679&jsn=944
With JL4: https://www.rockauto.com/en/moreinfo.php?pk=1416728&cc=1431156&pt=679&jsn=945
You did not say WHY they say these parts are needed. You always always always want complete documentation when dealing with ANY shop.
