2004 Tahoe LS 4WD
Hello,
Tahoe sat outside in the rain for a couple of nights and the battery was stone dead. Nothing was left on.
I swapped out the 0.00V stone dead battery for a charged battery. I left one cable off and used a multimeter set to 10 Amps DC to close the circuit as needed for testing.
First try with ignition off, it pulled 10+ amps current. I assume it was recharing some capacitors?
We pulled a few fuses and read 3.6V. Put them in one by one, and it stayed at 3.6V. So the 10+ amps was a one time thing. But still far too high, obviously.
Removing the LBEC 1 (50 Amp) fuse drops the drain from 3.6A to 1.6A. Left that one out.
Removing the IPC/DIC (10 Amp) fuse drops the drain from 1.6A to 1.1A. Still too high! Left that one out.
We removed EVERY other fuse--under hood panel, driver door dash side panel, drive left foot kick panel--the current never dropped below 1.1A.
Checked the wires feeding that kick panel, inspected the insulation, wiggled them... no change.
Unplugged the one car phone charger, so nothing in the front or rear cig plugs... no change.
Checked the trailer plug wiring, it's fine (shouldn't matter, all those fuses got pulled at one point or another).
What is going on here?
And what do those two fuse circuits do? I read the details on the LBEC but having pulled the other fuses am not having any light bulbs appear over my thick skull.
Thanks in advance.
Hello,
Thanks in advance.
