Replaced mine about a year ago, it was doing the same thing. I did not replace the MC, it still works fine. It is pretty straight forward, but is kind of a PITA. I did it without draining the MC or taking the brake lines off of it. It can be done, but you have to be careful not to bend/kink the hardlines. Also, if I recall, removing the 4 nuts on the firewall is pretty tight, very little room to get a wrench in there.
GMSI instructions: Vacuum Brake Booster Replacement
# Disconnect the negative battery cable.
# Apply the parking brake.
# Remove the master cylinder nuts.
# Remove the master cylinder and bracket.
# Disconnect the vacuum hose.
# Remove the retainer.
# Remove the stoplamp switch.
# Remove the pushrod.
# Remove four nuts.
# Remove the booster assembly.
# Remove the gasket.
# Install the gasket.
# Install the booster assembly.
# Install four nuts. Tighten the nuts to 36 N·m (26 lb ft).
# Install the pushrod.
# Install the stoplamp switch and retainer.
# Install the vacuum hose.
Gauge the booster pushrod. I did not do this, need a special tool, didn't seem necessary.
# Install the master cylinder and bracket.
# Install the master cylinder nuts. Tighten the nuts to 30 N·m (20 lb ft).
# Release the parking brake.
# Connect the negative battery cable.
