Ride after a drop
Discussion in 'Lift Kit and Lowering Kit Discussions' started by Jake, May 11, 2008.
  1. Jake
    Jake New Member
    29
    Dec 26, 2007
    I was wondering how different the is on the hoes when they are dropped? i think mine would look better with a mild drop but if its going to mess up my suspension and ride like crap then im not going to do it.. Thanks for all input
    oh this is the first thread in the new section haha
  2. treepete
    treepete Full Access Member
    1,319
    Sep 24, 2007
    Genesee Twp, WI
    I also had concerns on how my 99 ykuon would handle after lowering it.
    If you get a decent kit, and also new shocks, and make sure you have no rubbing when there is a lot of chassis roll, you should be ok.
    My ride DID change a little bit, but I got used to it in short order. Bumps were a bit bumpier/ ride was a little stiffer, but overall, the change was unremarkable.
    I think someone that has REALLY dropped the truck 4-6" could reply with their opinion. I did the belltech 3/2 and 4 nitro drop shocks, and I was pleased.
    Hope that helps a little.
    And way to be the first poster in the new thread.
    Pete
  3. Alex33
    Alex33 Full Access Member
    256
    Sep 21, 2007
    I did a 2/3 McGaughy's kit on my truck and it rides fine to me. The rear stiffened up, but it's not harsh. The front seems like it's actually softer, but not bad. Overall, the vehicle doesn't seem to float over bumps as much, which I like.
  4. stockergt
    stockergt Full Access Member
    70
    Mar 12, 2008
    alot of things determine how your hoe will ride. I did the Belltech 2/3 drop on my denali (which has the air ride), it wasn't the drop that changed the ride but the 22's. I am actually about to put the stock wheels back on for a week and I am curious to see the difference.
  5. boostaholic
    boostaholic Full Access Member
    Jan 1, 2007
    You'll need to do a few extra things if you want to get your ride back such as trimming the front bumpstops and installing shorter shocks (if you don't have autoride). I dropped the front of my denali just over 3" and I lost quite a bit of shock travel, since I have the autoride I have to go to extended measures to install shorter shocks but the ride is fine as long as I don't rally over huge dips (I have approx 2" of shock uptravel with the stock front shocks). I would recommend doing this for the rear if you plan to keep the truck awhile. Mine rides great for the 4" of rear drop but this will free up some travel and rides like butter
    [​IMG]
    http://www.djmsuspension.com/Articles/FreeTravel.htm
    I'd also install some larger sway bars, my truck handles much better but I'm not taking full advantage of the lowered stance with the mushy stock sways.
  6. Jake
    Jake New Member
    29
    Dec 26, 2007
    Thanks for all the input...so what am i looking at here as far as cost goes?
  7. Alex33
    256
    Sep 21, 2007
    I got my kit for 280 or something. But I know they sell the 2/3 basic kit (keys, coils, shock extenders) for around $300. The 2/3 deluxe kit (spindles, coils, extenders) usually runs about $400 i think.
  8. 06tahoez
    06tahoez Full Access Member
    115
    Feb 5, 2008
    Massachusetts
    It really depends on what method you choose to lower it. Kits can range from a few hundred to a full air ride suspension up to 5K.
    I opted for the low(er) cost alternative. I went with 3" Eibach lowering coils and cranked the stock torsion keys down (will replace stockers w/ 3/4 ton keys soon). I replaced my shocks with Bilsteins and added a set of Eibach sways.. Ride is rougher than it was, but then again I didn't expect anything less. I'm running 22s as well.
  9. Jake
    Jake New Member
    29
    Dec 26, 2007
    yeah i dont think i got that autoride....unless its the stablitrac..i have 20 but not looking to go bigger for a while...i looked at the site that djm and thier stuff looks like a well put together kit...i just did not realize the cost..once i have the 500 to spend ill ask more info...casue i wanna do it right once and not take any short cuts
  10. AaronJames
    AaronJames New Member
    May 9, 2008
    McKinney, TX
  11. boostaholic
    Jan 1, 2007
    Looks alot like my belltech kit, coils look a little off and they don't have the autoride links or bumpstops but my kit was around $190 iirc. I say fu*k it and just buy it, the keys are all the same I sold my nice powdercoated belltechs that came in the kit for $100 and used the stock 3/4ton keys out of my brother's dmax. Get some rancho rs9000xls or bilsteins and it should ride nice.
  12. Trend Setta
    Trend Setta Full Access Member
    363
    Dec 15, 2007
    I don't really care how it rides...cuz it looks dope as f**k
  13. Jake
    Jake New Member
    29
    Dec 26, 2007
    haha figured that coming from you but the ride is so nice that i dont wanna give that up but im sure i will
  14. boostaholic
    Jan 1, 2007
    My P's came to visit last week and my mom said my truck rides better than her maxima. You don't have to sacrifice ride quality unless you buy some really buster parts or really mess something up, these torsion bar trucks ride pretty decent lifted or dropped as long as you have some good shocks. When the hell you gonna drop your truck trend? I swear I'll be done with college by the time you get the bums out of your wheelwells, do work son!
