Ok, I finally ran my 4g power wire through the firewall.
On the passenger side, I put a 3/4" hole between the AC/Heater fan and the the wiring harness. I put it as low as I could because the harness's molex plug is kinda big in the engine compartment. In the hole I used a Streetwire Firewall Bushing
I ran the wire in the kick pannel and under the passenger's side door still. Under the door still on the front passenger's side is a conduit. The 4 gauge fit fine in there.
I had to unbolt the seatbelt. It take a T50 Torque bit to remove it. I ran the wire under the B Pillar cover and under the passenger's side back door still. From there it goes to the distribution block and amps.
Power is grabbed from the secondary battery. A fuse is put inline within 12" of the battery.
The 4g power line was run in black split loom and goes along the firewall. On top of the fan shroud, you'll see 2 more runs of split loom (since they're dirty like the rest of the vehicle, you don't notice them as much.) One of those split looms has a 4g wire that connects to the battery isolator (which connects the 2nd battery to the electrical system). The other split loom contains the switched relay for the fog lights, trigger for the hood switch pin for the remote start and a power wire for the additional accessories. The power wire is fused within 12" of the battery and run through the grommet under the radiator overflow vessel.
The power line was dropped down by the evaporator can and into a hole below and to the right of the Molex plug.
Here's a close up of where the hole was drilled. Note the position of the Molex plug.
Here's where the wire came into the vehicle. The round cover on the right is the AC/Heater fan.
I removed my glove box so I can add in extra fuse pannels. Each row is different. 1 row is constant +12V, one is NO +12V and the last one is +12 V NC. I use the NC to activate things like a blinking security LED when the truck is off.
The 4g wire was run into the existing conduit that is located uner the door still. I had to remove the seatbelt (T50 torx bit) to get everything in place.
The 4g wire was also run under the rear still and over to the amps.
With everything buttoned up, you can't even tell the 4ga wire is there.
Hardwarz
![263-635m.jpg](/proxy.php?image=http%3A%2F%2Fwww.partsexpress.com%2Fimages%2F263-635m.jpg&hash=11bb1d937c080117fc3497ac8f942e05)
![dsidexd0.jpg](/proxy.php?image=http%3A%2F%2Fimg48.imageshack.us%2Fimg48%2F1043%2Fdsidexd0.jpg&hash=0d65107a1cc94ec002871bf56526adaa)
![engfrontxk1.jpg](/proxy.php?image=http%3A%2F%2Fimg48.imageshack.us%2Fimg48%2F3314%2Fengfrontxk1.jpg&hash=222f8059acc19c3e717d07916a68cb28)
![firewallclosenn4.jpg](/proxy.php?image=http%3A%2F%2Fimg48.imageshack.us%2Fimg48%2F5830%2Ffirewallclosenn4.jpg&hash=2ef26ed80ca181a75100565a9955d1e0)
![firewallcloservq6.jpg](/proxy.php?image=http%3A%2F%2Fimg48.imageshack.us%2Fimg48%2F1893%2Ffirewallcloservq6.jpg&hash=cc7e31c56d4e1c85e2b48051dd9435fb)
![insidekc8.jpg](/proxy.php?image=http%3A%2F%2Fimg48.imageshack.us%2Fimg48%2F5166%2Finsidekc8.jpg&hash=d9f515b254f396fdde179965929c3e1b)
![gloveboxwz6.jpg](/proxy.php?image=http%3A%2F%2Fimg48.imageshack.us%2Fimg48%2F5696%2Fgloveboxwz6.jpg&hash=9a60e9c014affa97451e67e035343c5c)
![conduitpk2.jpg](/proxy.php?image=http%3A%2F%2Fimg48.imageshack.us%2Fimg48%2F169%2Fconduitpk2.jpg&hash=81ea148ac72e832d178b017bccd5b9da)
![rearvm4.jpg](/proxy.php?image=http%3A%2F%2Fimg48.imageshack.us%2Fimg48%2F8369%2Frearvm4.jpg&hash=32a51671f331c2393127ff5e94b5da04)
![donenl0.jpg](/proxy.php?image=http%3A%2F%2Fimg48.imageshack.us%2Fimg48%2F2299%2Fdonenl0.jpg&hash=0c441d84b263c47f0d7affbf86da44fc)
Hardwarz
